CB550 F wiring issues
I got mine working by connecting it 'backwards'
I guess there is a diode in there soldered in wrong?
So, the entire system appears to be connected correctly. with the regular signal relay in, i am getting 12 volts everywhere, and all the switches work (but do not flash).
When i install the new 12v electronic flasher (i have two new ones, neither works, so i know it is not the product), i only get 6 volts at the wire going to the signal. I am getting 12 out of the flasher, 12 into the left hand controls, 12 out of the controls to the signal. wire then hits a y-tube for the idiot light and the turn signal. i get 12 here, and then it appears as if each light (turn and idiot) is pulling 6v.
is this correct?
i disconnected the idiot panel to see if that would help. it allowed 12 v to get through to the turn signal, which then came on, but no flashing.
new update:
Incandescent bulb flashes with the new relay (not the old ones), still nothing with the LED.
here is a photo of the flasher relays i have. Any ideas?
Johnny, try pulling the connectors from the idiot light or pulling the bulb, itself. Any difference?
I get 12 volts when I do that, but still no flashing.
I am wondering if my 'flashers' are the wrong type?
I have checked wiring, fuses, lights, switches, and flasher, cannot locate a problem.
Hey Dukie, that would not be the problem. the bike electronics are 100%, tip top. 12v everywhere, proper voltage, etc....
however...........
I FIXED IT, EVERYTHING WORKS ;D ;D ;D ;D ;D ;D
turns out, the flasher was the issue, 3rd one was the charm. The first two where apparently both faulty. Also, some of the flashers are labelled as "electronic" when they are actually electro-mechanical. The clear one below is WRONG, the black one is RIGHT. all about the 31, 49, and 49a!
How did you wire that new one in? I've got the same one - it's got three prongs whereas my factory flasher only has two prongs :-\
Yeah, I did. Worked like a charm. Connected the ground, even though the original lay out did not call for it. You need to, since the new flasher uses electricity, versus just passing it along.
ok, cool. I hooked it up today but have not tested it. I believe both my original and the new one had letters labeling the prongs (B and L?) So I just matched those up. I assume the third (empty) prong would be the ground then?
Thanks again,
Devon 8)
That's what I meant earlier when I asked about ground, didn't explain myself very well though
