Cb550 need to start it
Qnzbase55
I just found a 1977 honda cb550f super sport I know the engine turns over but I'm not getting to spark at my spark plugs I know it might be the points or coil but need to make sure I wanna fix up the bike but don't want put money into it until I see the engine running....,
Test the compression -- that'll let you know what you're getting in to for the most part. if the bike has been sitting, a couple drops of oil down the spark plug holes would be good before you try to turn it over. But... that might give you a false good compression reading, so go back and check it.
Set up a hot lamp under the engine for a few hours to get the old oil warm, drain and change it w fresh.
Squirt a little marvel mystery in the spark plug holes and let it sit while warming and changing oil.
Open the tappet covers. Use an oil can to squirt some oil on the cam, tappets, valves and cam chain...as best you can.
Pull the carbs off, open them and clean.
check static timing and adjust to suit. Toss new pugs in her. And a good battery.
Give her a kick or 100 of them.
Only a minimal money spent on oil, plugs and battery.
OH yeah, Welcome to DTT. :D
and like Carn Chicken said you can test compression while you got the carbs off to clean them.
