CB550 strip and build
bissinger
Ok, so I picked up a CB550 for 400 bucks that had been sitting for a REALLY long time. long enough for gas to solidify in carbs, tanks and petcock rendering them useless. The Fork seals are shot, the engines leaking oil like a siv and theres a ton of random parts that need to be replaced. so on with the pics.
All of the new parts that are going on:
Tank
Petcock
Carbs
Clip Ons
Fork Seals/Oil
Head Light Brackets
New top end kit on the motor including cylinder base gasket
oil pan gasket/filter
Cafe seat
Smaller turn signals/taillight
Smaller exhaust.... Any ideas?
and assorted other crap
My plans for the bike are:
Clip ons
Shaved handle bar clamps, I will use those threads to mount a piece of sheet metal and put LEDS for the oil, neutral, turn signal, high beam lights
keeping the fork gaitors
small headlight brackets to get the huge fork covers off
Painting it a Deep Navy Blue
Copper Exhaust wrap to accent the paint
velocity stacks
fairly open exhaust which will need to completely rejet it with the stacks
couple other things
this is she in her original glory
starting the tear down
the motor had a shitload of old nasty burnt carbon you know the story, so it all went to the machine shop to get prettied up
after spraying the frame, mocked up with the tank and seat
carpy seat. great quality
the seat needs to be modified or the point were I am mounting it. no idea, need to look at it a bit more indepth once im done with the forks.
If you guys have any ideas or comments good or bad let me have it
got a few things done today. since im going back to school i didnt get a chance to rebuild the forks, so i just threw them back together.
I mocked up the clip ons and head light brackets to just get a feel of what it would look like so here's a pic of that
I ground down the triple trees since I wouldnt need the mounting points for handle bars considering I am running clip ons. I will reuse the holes to mount new LED neutral, high beam, turn signal and oil lights on a sheet of aluminum or something along those lines.
and last but not least the tach and speedo that I got off of the cb350 I picked up last night for $100. Looks like the tach will work, speedo, probably not. I will be building custom brackets for these suckers
You know whats funny....I looked at that bike about 2 months ago, guy didn't like my offer. But good luck with it. Should look nice once its cleaned up!
no way! what'd you offer him if you dont mind me asking?
he wanted like 750 for him, and i figured it was a good deal for him to get 400 for the bike. I think it was actually a little high.
He was asking 800, my uncle and I looked at it and what not, offered him 350 he never got back to me about it.
Now that I look at the work you are doing it was a bit more than I had expected. Didn't realize how bad the engine was.
yeah i bought it with the intention of doing the work. the carbs tank and petcock alone had to be replaced becuase of so much corrosion. it probably wouldnt have ran well without stripping it completely and putting new parts on it.
hey nice build, i noticed you're going the same route that i went with the top triple tree/clip ons, heres a pic for some ideas which seems close to what you're talking about..
The seat looks nice on the bike, let me know if you need tips mounting it!
I do, I hid the electronics between the frame. I may have a couple of seat mounts welded up to the top of the frame, but Im unsure of what to do about that, or where to support the fiberglass to make it sturdy and for longevity. let me know what tips you have
well, with fiberglass, just try to get mounting points around the center of load, so, 4 hard points around where you sit should work well, if you hinge the seat, just follow the same principle, make sure your mounts are even so you're not overstressing any point. also, fiberglass is a lot more durable than most people think, it doesn't fatigue like metal, so the only way it'll break is really by catastrophic failure where you overcome it's strength all at once. it doesn't wear out like aluminum or steel parts
:D "when you see it...."
updates
I got the wiring harness in and put the front wheel on and headlight/brackets.
Also I bobbed the fender and bent it in the process, so I need to take that off and fix it/touch up the bob. I didn't have much time becuase im taking 19 credits at school
this is where i stand with hiding the electronics....
I need to fab a support for the seat to bolt to and the electronics to bolt to the bottom of it, and take off the rest of the tabs, That will happen when it gets powdercoated over the winter.
I just fabed up a couple of small brackets, I lost the stock bracket and need to find it
that's really it for now i still need to paint the rear swingarm and pick up tires, get the motor in and a bunch of misc b.s
couple of random ones.
the old xl500 sitting in my basement too
a pic of my pup that was on my phone
but seriously let me know what you guys think. Im kind of liking the stock red, but the dark blue with tan exhaust wrap sounds enticing....
valvesprung said:
Sure! I won't be ready for a while, but I like the look and it'd be nice to be able to get to him later!
bruce@virtuallyjunk.com there ya go, also he has a website. http://virtuallyjunk.com/
He said he's got plenty of mufflers I would email him for sure.
