Shooter
I made a bit of a screw up last night.
I decided to squirt a bit of grease into the swingarm via the nipple prior to reassembly and insertion of the swing arm shaft.
Pumped in a bit and soon after I discovered that one plug end had pushed out.
Thought I could just squeeze it back in...no way...
so I then thought Mr Hammer and a block of wood. OOPs.
Shattered the plug. What is it made of - plastic? soft metal? ????
Will get new plugs and probably the bush whle I am doing the fix.
Kind of wondered how the grease gets thru' the bush etc to the shaft?
