Hey everybody, I'm just getting around to posting a build thread because I've fallen in love with the Jim Lee tail section from Slipstream Cycles and I'm shooting for a discount
I always start builds with intentions of documenting everything, but laziness normally prevails.
So anyway, on July 22nd, I went on an 8 hour round-trip with mi madre to the small town of Guttenberg, Iowa from my house on the border of Iowa, Missouri, and Illinois to pick up this 1981 CB650c for a steal. It supposedly ran when parked, but the tank was filled with varnish and the carbs needed a good cleaning.
No big deal, I was raised in a garage and I'm no stranger to projects. Never having been to Wisconsin and being so very close, I splurged and bought me and my mom lunch at Rowdy's Bar and Grill in Prairie du Chien, Wisconsin. The people were all friendly (if not a bit obnoxious), and it definitely made the trip. On the way home, we checked out the Field of (shattered) Dreams filming site. Not impressed.
New battery from O' Reilly's and all the electronics came to life. Engine turned over, good compression, good spark, no noises other than what I expect is the cam chain rattling from lack of tension.
First order of business was to strip it down, removing the luggage rack, airbox, all the gaudy factory shit that was left on for reasons unknown. Not having any parts to replace what I've torn off, I got to work on the wiring. Oddly enough, the harness is designed so that the nasty fusebox on the bars can just be unplugged and everything is still fully operational. The harness was torn apart and stripped of everything besides guage lights, headlight, and taillight and soldered the connections back together. I keep wanting to tape the thing back up, but I keep finding different things to do to it. At the moment, I'm just planning on reinstalling the headlight plug and buttoning it up, but things change.
All of the left hand controls were done away with completely, the indicator bar removed from the guage cluster and the off-run-off wired to run whenever the key's on. Also relocated the ignition to the airbox's former spot, waiting on metal to build a mounting bracket for it.
Having worked (part-time in a busy restaurant, mind you) for around 100 hours since I got the bike three weeks ago, I've saved up enough money for some parts. First thing I bought was a set of DOHC CB750 carbs. The ports don't line up with the head, so I bought a length of radiator hose to chop up and make boots, but I'm terrified of spacing and cutting it wrong, so I'm waiting until I can get some knowledgeable supervision.
Next up was a Magura Trapdoor throttle that had a nitrous switch already mounted in the casing, though I'll be running it to my starter as soon as I find a new switch. I accidentally broke off a spade terminal when I was playing with it :-[ After that came the tank, off a 1978 CB750SS. I thought I'd read somewhere that it'd fit, but I'd have to relocate the rear mount, though that turned out to not be the case. It bolted in to the factory positions with the factory rubber. I'm currently waiting for the delivery of a set of Factorykiss levers and perches and a set of matte black clip-ons. I bought a set of CB450 forks off a user here as I was intending on lowering the front end, but it wasn't until they got here that I realized they had different axle setups and caliper mounting points, so they're getting resold.
As it sits, it looks like this:
My next purchase is going to be a Jim Lee tail from Slipstream Cycle Works. I went and measured the tank for reference, then measured the pixels from point to point and found the ratio for inches to pixels (Just to get a decent idea of the look) and photochopped it in. It flows beautifully from the tank to the tail, which I find is the main reason I don't like many cafe builds I see.
I will admit, I didn't like the Comstars originally, but they're growing on me. I'm seeing more and more that spokes are played out and a performance bike of the era would have the mags as opposed to spokes, the same reason I'm keeping the air-assist forks. I'm a bit undecided on color as of yet, but seeing as how I'm a huge ACVW fan, there's a good chance it'll come out of this either PG/SG or Mango.
I'll be trying to keep this more updated from now on, but school's about to start and I'm about to lose most of my free time to Chemistry and Physics, but I promise to try my darndest.
