CB750 SOHC Airbox Mod
Koestum
Coast to Coast
Well I finally went to a scrap yard today and found a couple aluminum plates that were the base of those food heating lights. I'm using part of one as the block-off plate for the top half of my 1975 Honda 750 air box. I'll get rid of the bottom of the box and stock air filter to mount aftermarket air filters to the plate instead and clean the middle up a little. My 750 currently has open velocity stacks with original jets (previous owner trick) which means it likes to foul plugs quite often.
Here are the plates I found, about 1/16" thick:
I traced the original plastic divider onto the aluminum with a pencil:
I used a cutoff wheel in a grinder to cut out the piece:
This is how it mounts in the top of the box. I'll need to shorten the screws a little and put some plastic edging around the plate before I'm finished so it won't chew up the plastic box and it will get a better seal too:
When finished it will look something like this:
The other side:
The original box bottom has two openings to let air in. The whole purpose of this project is to clean up the bike a little but mainly to keep from having to re-jet the carbs. To do this right I figure I need to restrict the air flow to the same size openings. The ends of the opening is about 45 degrees so I'll only measure one side. It measures about 3.25" x 0.55" for an area of about 1.8 square inches and since there are two openings it's a total of 3.6 square inches. Using some math I find that two circles with a radius of about 1.6" should give me very close to the same throat area of the two elongated holes in the original bottom of the air box.
Amazingly enough I have two unused filters from my 450 that should do the trick or at least be close enough that I will be able to run plugs a lot longer than 50 miles without fouling. The camera angle is a little off here, the calipers are actually measuring the smaller lower opening. The opening is a little larger than what I need but a lot closer than what I have now.
Now I just need to cut two holes in the new plate find an easy way to mount these two filter to it. Maybe a trip to the plumbing section of the hardware store will yield some type of neck that I can rivet to the plate and clamp the filters to. If anyone has any simple ideas I'm open to listening.
Another thought I had was to make another plate, cut the foam off the filters, drill eight 0.5" holes in both plates to allow air to get in, and sandwich the flat filter foam between the two plates. This would clean open up the space behind the engine even more and eliminate the need for some type of neck to connect the filters to. Thoughts?
