Changing the stock muffler?
NBraun
I have a 79 GS750 with the L pipes, and would like to change the muffler's. I don't need to spend another 300 on a header for my bike. I don't really want to cut the pipes, though thats probably against what goes on here, the whole exhaust is nice and rust free so if i should ever get a 4-1 i could resell the stock one. Anyways, it appear that where the trumpet starts, it just slides into the pipe. Would i be able to just remove it, or, how are the mufflers attached? Id really like to run the DCC 14" muffler on my stock header. Thanks!
I dont know if its the same but on my '85 GS250, the muffler is just clamped on, if there is a clamp, try undoing it, and the muffler mounts and seeing if it comes off.
be careful tho, mine was quite rusty, I used a shit load of WD40 but when i pulled it off it tore the pipe apart.
They usually pretty on the outside and seized solid on the inside, I havent had much luck getting apart old pipes without wrecking them, but you can always try... I think gs pipes are double walled too, just so you know.
