cheating or forbidden?
vandito.cb
new to wiring and recently started learning by fucking up everything i get my hands on. is this a viable option to, in this case, make a common power or ground source split out 2 ways from a connector?
disregard the crimp, length, etc. as i just stripped and crimped quickly to get a picture.
Sure it is. The factory does this a lot with grounds more often than +ve's but it's still OK as long as the wire is large enough to handle the current / load.
i'm running very few electronics aside from the necessary ones to keep everything running, headlight/brake/tail.
my largest consumer as of right now is my 60w highbeam until i can afford (and find something without a bluish tint) an LED h4. i believe the runner up is a whopping 10w, followed by 3, then 1.
something similar to that picture is what i came across when I tore up my harness and found the starter safety switch wiring setup with the clutch switch and neutral switch wires merging.
what exactly are those called? are they just essentially what you'd find in an insulated butt connector if it wasn't...insulated?
Crimp Tube Connectors. You can either crimp, solder or both. You can make your own out of a short length of 1/4" aluminum/copper tubing cut to the length you need (3/8") Use shrink tube over after soldering/crimping.
hey did you get that terminal locally?????????!
Nj732port said:
haha damn! ill be placing my order tomorrow
it doesn't hurt to order extra terminals too just to have laying around. i got the crimping tool from there too...works like a charm although my HF strippers are a different story.
