chopping the kickstand
frenchy
Active Member
I slapped on some 11" shocks on the back of my cb750. Looks good but the sidestand is too long to use. Any advice on cutting the sidestand down?
Thanks
Yeah... it is pretty easy. In fact Joe just chopped his and his results were pretty factory looking. Hold the bike in the position that it should be at, remember to keep more or less the original mounting location as it was triangulated by the factory to be correct, geometry wise. Take a tape measure and measure from the mount to the ground. Then measure a few more times and start chopin!
Cut the foot off first near the base and take the length out of the lower section of the arm, then just weld the foot back on... super easy, and depending on your welding skills you may not even need to grind it down... Then just paint of powder coat.
This is Joe's that he just did a couple days ago. Scroll halfway down the page.
http://dotheton.com/index.php?topic=12553.390
Thats why i measure like million times ;D.... even then I feel like I am gonna regret it, the first cut is always the hardest
cut small! you can always cut more off it is hard to add more on. you can also bend the stand! heat it with a torch and then pop it with a hammer a few times, that is how i bent mine for the CB350
here is the the pics from my recent cut weld job
measued my lean angle and where i would want the foot, cut that and got the angle right on the belt sander
welded
after powder coat
you can see the bend in the stand in these pics but i do not have a how to on when i did it
The welded Kickstand looks great Joe. So heating and bending works too? I was wondering if that would affect the tensile strength of the stand...
That 350 looks wicked.
man it is a kick stand, the fact that it is coated is already 50x's better than most stands... a bit of weld splatter was the last thing on my mind with 8 bikes in my shop and this being my personal project. although i have to say, i do agree.
welding it works great, the bend works just fine as well on the lighter bikes. i would not bend a harley stand but for the little CB's hell ya
