Tune-A-Fish© said:Have you tested to see if its grounding out (meter from frame to fuse connector with fuse removed) ? did you do any work recently around the hand controls, have the tank off or anything? Pinch points first and then look for chaffed harness... look in the headlight bucket for loos wires... may be a good time to get some CRC electrical cleaner and hit all of your connections, use needle nose to get a grip up close don't yank em apart.
Good luck mang... electrical gremlins can be a pain.
TJGM said:Thanks,
Hate to sound like a dummy, I have power across the fuse terminal and the frame, means something is touching the frame somewhere ?
Thanks,
~T
