jdub64
So today, I removed the right side engine cover and clutch basket on my CJ360. The clutch plates were sticking, so I soaked them in clean oil (Rotella T 10w30) and re-installed. While the cover was off, I cleaned the oil filter centrifuge and the oil pick-up screen. I re-installed all parts and finally successfully adjusted the clutch. The engine fired up on the first kick. I let it idle for 10 minutes then took it for two 1/5 mile loops around the neighborhood. One my third attempt, the engine stopped. The kick start pedal wouldn't budget. After rolling it back home, I let it cool and 20 minutes later I was able to turn the engine over at the alternator stator. It seemed to turn over as normal as it would when setting timing and adjusting the valves (which I also did this morning).
After doing some reading, I now know I did not line up the oil filter cap rib with the rib on oil filter rotor.
I also did not re-install what looked like a redundant, stretched out o-ring loosely installed around the oil screen tube. (the o-ring was red and clearly so stretched that it wasn't doing any good. The correct black o-ring was still in the engine case where the tube from the screen mates to the case).
I'm using Rotella T 10w30.
Would any of those points factor into the lack of lubrication? If I fix my oil delivery problem, do I now have a much shorter engine life since it seized?
The engine is a stock CJ360 16K original miles running stock carbs, air filters and exhaust.
