cl 350.....not another -update #1
zimm
its a 71 got a 69 cb tank
goin to repaint the white and green
had it running today even tho the carb floats have holes in them >:(
plans: paint everything, 2into1 using the cl pipes, clubmans, somthing creative with the tuen signals and usa a 69 tail light
i have some peices of cardboard in moack up for the seat, goin to cut sheat metal and bend it monday @ work
Re: cl 350.....not another
hell ya man! make it happen!!! take pics show off your work as you go... should be sick!
I'm a real sucker for the old style tanks love the knee pads and the wing badges.
The CB350 lend it's self so well to being cafed and with so much tuning gear available they can be made to hustle and sound F#$^en awesome.
keep us up to date on your progress...lots of photos and think out side the box.
Rod 8)
got a little more work done today on seat and started the rear sets
cut some 18 guage as work....nice having a shear and press
bet it over the knee and tacked it into place
was a tricky to get a nice round bend, had a small crease but worked it out after it was in place
welded along the sides to the seat pan and cleaned up the welds still need a little work but few more peices to add
not sure about the tail light ....what do ya'll think?
cut out some side peices to clean up the seat pan and made a peice to fill the hump
sorry pics are crapy!
for the rear sets i have a pair of h-d passenger pegs lying around thinking about using those or making some ? but i took the shifter and linckage and mout of my parts bike and ground the weld off of the shifter spindle, removed the spindel and moved it back on the mount and tacked on for now so if all is well i will just need to extend the linckage rod. the shifter has been braised at one time i will probly shorten it some not sure anout the breakes but i have another petal to play with
i striped my titled frame down 2day to paint or maybe powercoat and found that the frame is broken on both sides under the swing arm support/pass foot peg mount is this a common problem with the cb? this is the 3rd one i have had and never seen it before
im goin to weld it up and see what happens for now maybe and a bace or 2
Is there a flange on the tank for the rubber knee pads to fit into? I have a 68, but the tank is of unknown origin...looks like it's the same shape as your tank, but no pads, just smooth sides.
--Casey
ya theres a flange that the knee pad slides in to the rubber was hard i used a heat gun to soften it up some
im not sure but i think this tank is off a 69 cb and 69 cl tank was the same shape without kneepads
Re: cl 350.....not another -update
frame is coming back together tin work is done on the seat preping for paint
found a led tail light and signals on ebay
im really itching to ride so all day tomorrow in the shop
