CL175 Need help getting right pilot jets
zcrenna
As I said in the title, i have a '73 CL175.
It currently has #35 pilot jets. it is in need of bigger pilot jets, however, I've been having a pretty tough time finding proper pilot jets for my carbs.
the carbs appear to be the stock Keihins, i can best identify them as the PE series. there is a "20" stamped on top of the carb caps, which leads me to believe they would be PE20's however, I've read posts about the CL175's having 22mm carbs stock. so I'm a little confused, if someone could point me in the right direction on which model of carbs come stock with CL175's that would be helpful. (all CL175 carbs I've seen have "20" stamped on the cap..)
Next, I found Mains for my bike from JetsRus. however the site doesn't list having my pilot jets.
checking keihin's site, the part# that looks the most like my pilot jet is listed as N424-24-**
JetsRus has that exact part number (just not listed as being compatible with my bike..)
I've done many searches for my pilot jets, checked ebay, been all around.. no luck except for the above model number.
I'm attaching a pic of what my pilots look like and what jetsRus has listed as N424-24-**.
they look identical, except that the one on their site has a little longer base, but I'm not too concerned about a slightly longer base going a little deeper in the bowl, obviously the threads fitting is priority.
check out the pics and let me know what you guys think. Should I just order them and if they don't fit, return them?
last resort option is i could just use a micro drill bit to bore out my pilots to the equivalent of a #38 or #40. anyone had any success with this?
thanks a lot. Zack
On the throat of the carb there should be a raised number that will tell you what carb it is.
