Irishluck002
Hi Guys,
I've got a stock CL200 that I've been working on this summer. Since I've gotten it I've replaced all the clutch (then adjusted), new battery, cleaned the petcock, cleaned the oil filter, a few oil changes, muffler patch welded (baffles sound a little clanky in there), new exhaust crush gaskets, and adjusted the cam chain tensioner. I haven't adjusted the tappets, timing, or done a compression test yet - and when I got the bike the right plug was dark black and wouldn't fire - a new plug has got it seemingly running now (Exhaust at least gets hot)
The bike runs okay - but still tops out around 55-60mph. I haven't opened the carbs up yet but I've got new jets (35/95, per the manual) and 2 honda carb gasket kits on the way. Currently the bike will idle smoothly, but at 1,500-2,000 rpm (higher when hot), and that is with the throttle screws about 3.5 turns out and the air screw the suggested 5/8 turn out (opposed to the cb200's 1 and 1/4 turn out). I know that the idle should be about 1,200 and that the throttle screw shouldn't be more than 3 turns out - so before digging into the carbs I wanted to see if anyone had any thoughts on what could be causing the bad idle and poor performance, and any suggestions on procedures to check prior to going through the carbs. The bike has stock air filter (looked very clean - only 2,500 miles) and everything else is stock.
Thanks in advance
Thanks in advance
