Cleaning Master Cylinder Bore
dcwp
Coast to Coast
Has anyone ever used an ultra fine polishing wheel to clean the inside of a master cylinder bore?
The one I want to use has some corrosion inside. It isn't bad, but it's enough to catch the piston sometimes. Brakes of course I want to be as flawless as possible. I did some cleaning with toothbrush, but still a tiny bit of roughness so I was considering getting a super fine sanding wheel or even a polishing wheel and sending it through with a drill or dremel. What I'm afraid of is that this will put extra scratches in the wall and cause problems with building pressure.
So do you think this is possible or should I just get a different MC?
Thanks
Dan
