clutch cable replacement
johnny gaijin
replacing the shift cable on my '75 cl360 there's a triangular piece of metal w/ three ball bearings in it that popped out when i took the crank case cover off. does the orientation of that piece matter?
thanks in advance!
Re: shift cable replacement
sorry rather it's a 3/4 circle with three bearings in a triangular spread.
i'm having trouble installing this cable. i put everything together and either the cable is too loose and doesn't disengage the clutch or i tighten it down and it starts to pull and then pops and slips and again the clutch doesn't disengage.
i know it's a matter of adjustment but i can't seem to get it...
what am i doing wrong?
the cable adjusters at each end are dialed all the way to make the cable as slack as possible.
the manual says to screw the adjuster screw counter clockwise until you get a slight resistance and then back off a quarter turn. this was absolutely not working.
my gas tank is currently being painted so i can't start the bike to test it but i think i've got it figured out. i think i just needed to dial that adjuster screw in another turn or so. if i pull the lever now it doesn't pop and i can push the bike when it's in 1st gear w/ the lever pulled so should be good.
thanks for the help though.
