cold compression numbers on a cb350?
56cbr600rr
I know that you're supposed to do the compression test with a warm engine. But being that mine won't run yet I got curious. With the kickstarter and throttle fully open I got 126 psi on the left cylinder and 121 on the right cylinder.
Is this decent?
Or is it completely meaningless being cold? i would assume it would rise some with a warm engine. It's a 1972 cb350 with 5800 miles.
It's a bit low but like you said, the motor is cold. Important thing is they are both fairly equal so no worries there. Get it running then check again. A warm motor will expand the metal in the rings, pistons and valves, creating a better seal.
