compression test results
Smoking Star
Left: 50psi
Right: 125psi
This is on a 1971 cb 350 with 9k miles... What do I do? part it out and look for a better bike or rebuild? what would you do?
Smoking Star said:
Left: 50psi
Right: 125psi
WOW. What a difference...
Busted rings on the one side?..
I dont know but I think it might be time to part it out... I know i wont be able to rebuild it. How much can you usually get from parting out a complete bike?
I was reading my clymers on how to do the compression test and it said the low compression can be rings or valves. You may have a stuck valve that could be easily fixed vrs. the full re-build. They say to put a tablespoon full of oil in the low cylinder and if compression goes up, bad rings, if it stays the same stuck/bad valve. Try that if you haven't already and it might help with you decision to part or build.
Maritime
It also depends on the availibility of rings etc for the 350, prob not as hard to find as cb200 rings! I ended up having low compression in both cylinders too and even though I had zero bike experience I decided to go for a rebuild. The only thing I had someone else do was hone and set the valves. Really not to hard, just time consuming, especially on your first go around.
Try dropping some oil in there first. 50psi is wicked low though, makes you wonder?
shouldnt my compression be above 150psi on both? I will try the oil in the piston, But It would only cost like 600 bucks for a new working bike. This one is getting expencive real quick.
A leak down test is the definitive answer to where you're loosing compression.
You put compressed air into the cylinder. The gauges on the tool tell you how much PSI it's holding and losing. If air is coming out the exhaust pipes, it's your exhaust valves. If it comes out the airbox, it's your intake valves. If it comes out the oil filler cap, it's your rings.
Rebuilding a twin engine shouldn't be that expensive, but if you do, the rest of the bike should be worth saving. If you can buy a nicer running bike with good compression for $600, then you'll be better off. It should cost you less than $600 to rebuild the engine however, and then you have a perfect fresh engine with new pistons/rings/valve job etc.
What TIM said! It all depends on the quality of the frame/body etc etc. New rings and a valve job shouldnt put ya under too much in cash, maybe just in time. In the end, it's all up to you.
You may even be able to find an engine. I bought my bike for 650, then a clogged oil channel toasted a piston, rebuild was not an option but I had a bike with brand new brakes, tires, etc... I found a parts bike with a motor, 2 more wheels and tires and various othere part for 150. I think the motor is good, will know tonight after my compression test but still only in for 800, plus a few gaskets etc.
Just a thought, I have seen plenty of CB350 on craigslist while looking for my parts bike. They were all in New hampshire and Maine, not sure where you are. Saw some complete bikes for 300.
Cheers.
Im in Iowa. If i can get around 500 for doing a complete part out of the bike on ebay I would. If thats unrealistic just fixing it is the way to go. although I dont really have a heated garage to work in making a rebuild a difficult task to complete
Smoking Star said:
Left: 50psi
Right: 125psi
depends on what's causing the issue...
if it's valve seating, lap the valves
if it's rings, replace the rings
if it's the head gasket... well you get the idea
in either case, if you're not prepared to take the engine apart, you could always sell it to me :)
why are you so quick to throw in the towel? I know everyone has different mechanical abilities and different levels of interest in getting their hands greasy, but replacing the rings really isnt all that hard. Im sure you can get a running bike for 600$, but you wont know anything about the history of the motor. If the rest of your bike is good, then Id strongly reccomend rebuilding the motor (if its even needed) or even having the work done for you. Youll know what you have on your hands, as opposed to crossing your fingers and praying that the 600$ running bike continues to run for at least a few thousand more miles...
Whatever you decide, good luck, I hope it all works out for you.
I guess your right, but it also has a clutch that needs replacing, new float for the carb along with a diaphram. and I dont have a heated garage to do any of the work on it myself. Im just unsure how much im willing to put into it before i will start losing.
ya, then maybe a new bike is in order. If all you want is a runner, then you have plenty of time to look before riding season.
On da rock with sour scow motors,,,wee look for valve troubles,,gizzem the wet tests but whem cummpressions is dat low's it's a vavle,,,trust's
