Ok, that is good to hear, because I was trying to test it with the kick start on the bench using my hands to actuate the kick starter and I was getting readings of 30psi which made me very nervous. I thought that this was probably the case though. I don't really wanna add acid to the battery I bought for this bike yet. Could I just use jumper cables and a car battery to power the starter for a few seconds or does the car battery put out too many amps for the electric starter?crazypj said:You won't get close to a true reading with kickstart on bench, just can't turn it fast enough
Electric start will work fine though.
PJ
Good to hear, thankshillsy said:You'll be fine with the car battery as long as you don't run the starter for more than about 5 secs at a time.
malloy said:to get a true accurate reading the motor should be at operating temp but you can still get a ball park figure on a bench. remove carbs as well.
