Cross-threaded spark plug. CL350. Any Help?
Blue Roller
A bike i'm working on had a cross-threaded plug on the left side. The threads are pretty mashed up. A new plug isn't going in smoothly. Any suggestions?
go and buy a spark splug hole chaser, coat the tap in white grease and thread it in and out.
If that doesnt work, buy a helicoil kit. Make sure it's a good one though, not the spring type.
I had to put a helicoil in my 350.
Before you chase any threads or drill/tap for a helicoil, you'll of course need to remove the cylinder head. Once the head is off, then you can tackle the job without worrying about where all the metal bits are going to end up, and you can take it into a machine shop if you get desperate.
Not true, if you're careful and take your time a thread-chase/helicoil can easily be done with the head still on.
The grease will catch most of the shavings, the rest can be taken out carefully with a pick, rags, and a vacuum if needed.
To Scary for me! I'd remove the head. I don't doubt you could do it, but I'd always be woried I droped something in there.
I used one of these on a couple of diff bkes with out removing the heads. works great ;D just expand a little at a time
http://toolmonger.com/2007/05/22/re-tap-spark-plug-threads-safely/
That is absolutely brilliant.
I've heard tales (though never a first-hand account) of suspending the bike upside-down while tapping out a plug hole. Obviously you'd need to drain all of the fluids from the bike, and it seems like a darn tricky operation to get the bike inverted, but it's one of those things that may be crazy enough to work. If anyone tries it, please post pics.
Man, you'd think it would be easier to pull the head off vs. draining all the fluids and suspending a bike upside down.
I've used Heli-coils before....but after using a Time-sert, I will never use anything else!!
Time-serts are actaually stronger than the original threads! I have used them several times without taking the head off. I do use a telescoping magnetic pen to chase it but I have never picked up any shavings. It works really well keeping the metal shavings out of the head!
