Cut ignition wires?
quadracer351
Coast to Coast
I was going through the old wiring on my cb750 while getting parts ready for powder coat, when I was heading down the bike I guess I didn't closely look at the wires coming from the ignition. When I did tonight I noticed some electrical and after taking it off found that the brown wire and the brown/white wire where cut and spliced together where the ignition goes into the write harness connection and the others where just cut and left. I was wondering what this would have accomplished and when putting my new write harness in should I put the wires back to original or leave it as is? Also why was the red and black wires cut just to be spliced back into themselves.
Sent from my SCH-I535 using Tapatalk 2
REd Wire = Battery +12V
Black wire = Switched ignition
Brown Wire = Tail Light (Switched
Brown/white = Rest of the Lights - switched.
the tail light has a separate wire because the oem ignition switch has a "park" position, which is ignition and lights off, taillight on.
so the original owner probably removed the lights, used a separate switch somewhere else, and ore, mistakenly cut the wrong wires.
Most likely the PO did not know what he was doing, or if he did, did not do it well. I can argue the merits of a good crimp over a good solder joint for hours, but there is no excuse for wire nuts on a motorcycle.
So the PO did a crappy job at best.
Re: Re: Cut ignition wires?
I just bought a brand new wire harness and want to keep this rebuild clean, should I leave it as is and try to make it look clean, fix it by putting the write back, or finally just buy a new ignition :/
At least clean it up. You can replace it later. Just check if the switch works. Might of cut them because of a defective switch.
Sent from planet Earth using mysterious electronic devices and Tapatalk
Before I tore it down all the electrical was fine (minus the blinkers not blinking because of a bad flasher) I'm just really curious what he was trying/what he did accomplish by doing that.
Hopefully that's it. Majority of the wiring is going to be new anyway so I'll just clean that up and make it work. I was planning on moving the ignition under the tank and shortening the wires anyway
