johnny2stroke
Bike is a 72 kawi h2, gotta send the bores and heads out for machine work. Thing is the two outer bores don't want to come off. There is a bit of play in each of them, I know they are not seized on (neither are the pistons in the bores). I've been taping on them with a rubber mallet, using pieces of thin metal/ wood/ plastic to pry without damaging but no luck yet. I can see a bit of a gap freeing up on both of them but have not gotten beyond that. I have sprayed penetrating oil in the head bolt holes and around the block to bore area. Still no luck. Any help would be much appreciated.
