did i F up big time?
rphilli550
installing the new handlebars on the bike today, ran all the wires...blah blah...didnt get it all back together before i turned the key on and tried to kick start it and i saw smoke coming from one of the wires on the kill switch...then the dummy lights turned off and now they wont come back on. what did i do? im hoping its something simple but i think i shorted out on the handlebars...HELP
The fuse should of prevent the short, maybe the previous owner did a bypass by using a wire. Then check your wiring & kill switch, maybe something got mixed up when you were putting back together.
F that. im not touching anything else...everything i've tried to fix on this bike has always turned out bad. when i take it in for tires on monday, i'll have the guys fix everything i need done.
If you left electrical connections disconnected and touching metal parts like your bars, you more than likely shorted out.
which should have been saved by the fuse right?
my only concern is the smoke
