Digital Tacho help
Sonreir said:
Nope. 16.6Hz is the standard for single fire tachometers.
Now I'm really confused, haha. Based on the information that the CB360 fires once per 2 revs I would need the pickups from both coils, hence the single fire adapter which is none other than a couple diodes and resistors.
I did hook up the tach w/ just to one coil and it "seemed" slow, I do not have a mechanical tach to test
You're right. I'm sorry. Next time remind me to get coffee before posting.
1000RPM / 60 (to convert to seconds) = 16.6
So that means one fire every rotation. Suitable for two strokes, 360° twins, or inline fours.
Awesome, thanks for confirming. Off to Radioshack i go
Re: Digital Tacho help...UPDATE
Hi All,
Update on my Tacho problem....I have checked and double checked the ground on the Tacho, all good in fact I made a new ground to be sure, back to the frame, positive wired to the switched ignition ...and the tacho pulse wire I have wrapped around one of the spark leads about seven times...works well and gives a stable solid needle...thanks everyone for all your contributions.
Eoin
So, I have installed my tach with the single fire diodes and still half tacho speed being reported on the gauge. Sonreir do you have any insight, or anyone for that matter. Sorry for thread jack again.
Tacho is a cheapo 16.6 hz ebay unit
You need to get some sleep instead of working all the time ;)
360 has half speed points cam not crank triggered so it would always read half of correct rpm.
Taking a trigger from both coils should give correct rpm reading though.
Glad to hear the wire wrapped around HT lead worked well 8)
Yes, and that is what i did, both negative posts from the coils, just like this diagram and I still have half speed
index.php
Could always try same as OP, wrap wire around HT lead and use magnetic induction to trigger?
You have wires connected to Yellow and Blue from points?
Thanks, I will definitely try that. Do you know if any diodes would be needed for that method? I would still need to wrap both coil leads and route back to one wire input on the tach. Thanks for your help.
I can't say for your tacho but SCITSU recommend taping the pickup along one plug wire and then going back in a Z shape for the second lead, so that both are in the same direction - not out on one and back on the other.
I have the wires from the negative side of the coils, they are XS650 coils, to the diodes then to the tacho input as in the diagram. I was unable to do the wrap method last night. thanks for the input on this guys.
I gotta say, I can't quite visualize this. Maybe once I am out there I will see what you mean, thanks.
Imagine two plug leads running side by side in the same direction.
What most of us would do is to tape the tracer to one lead and then cross over to the other lead and head back in the opposite direction. Looking down, it would be a U shaped wire.
What SCITSU recommend is start say 3" from the coil and tape the tracer for say 2", then take the tracer back to a 3" from the other coil and tape a couple of inches to the second lead. Looking down, it would be more like a Z shape. If I could draw I'd do it.
Yea, I gotcha now. Makes sense, thanks again.
found this too
