dowel pin removal/replacement
overdraft
Coast to Coast
took the case covers off my cb350... some of the dowel pins are stuck. is there a trick to getting them out without destroying them? or, if there isn't, does anyone know if they're still an available part?
thanks!
there are slide hammer type pullers made for dowel pins that make the job easier. I would find a machine shop that surfaces flywheels or machines cylinder heads and see what they charge. even auto parts stores with a machine shop should be able to help you. Puller kits are available, but not cheap, if this is the only time you will use it. using a slide hammer style puller usually means you can reuse them, but if they are damaged the machine shop may also have them available. maybe not by part number, but they may have, or can source, appropriate replacements.
You need to find a punch/bar that's a tight fit in dowel, then you can grip it without destroying it
I discovered a neat trick that worked on some hollow dowels i used the chuck on my cordless drill to grab them then WITHOUT running the drill give them a little tug, seemed to work good, donno if it would work on a solid dowel or not? Might be worth a try
I've used pointy nose vise grips a couple of times.
Any change in the dowel shape can easily be rolled out by inserting a rat-tail file and rolling the dowel with on a steel plate/vise with the file inserted.
Think Pizza dough.
thanks for all the input guys...
For The Win!!!!
Thanks for all the tips guys! Lovin' our community right now!
Heat and water, although I guess it depends on where the dowels are at, don't want water in the crankcase....
