Drilling my own discs ????
zixxerboy
I have plain rotors on my 79 KZ650 and want to attempt to drill them.
I have a drill press. Besides that some patience and GOOD bits what else would I need?? I thought about using CAD to come up with a pattern which I would print out and glue to the disc. Then I'd center punch each hole prior to drilling.
How tough are the rotors? I think mine (most) are stainless.
Any drill bit suggestions? How many holes to a bit??
Thanks
very hard to get the holes all in the right places. your idea of a template is good, if you have stainless rotors they are very hard to drill and need expensive drill bits made with cobalt, they can turn red hot and stay sharp. Centre punch, 1/8 drill, then 3/16 and see how hard it is and go from there. in general you can do this but it's tedious, long and each hole has to be slightly chamfered (deburred) when done to prevent it from "shaving" your pads to nothing in 10 km. if you have an old rotor or can get a junker you could try it first. check the cost of drill bits vs aftermarket drilled rotors maybe. Use the correct cutting lube as heat is the enemy. you might want to speak to a machinist about it first. Cobalt drill bits can be had through industrial suplliers cheapest, like a machine shop supply.
hey but doing it yourself is the challenge and feels good when you are done!
good luck! ;D
bw
Thanks
$40-$100 to send them to a shop to be done, i know cycle-x does them, think was saucer that told me he saw a place for $40
Great suggestion!! this would save a lot of time and maybe the co$t of ex$pen$vie bit$
