Dyna 2000 VS Dyna S
SaltCityCafe
So I am still learning a lot about ignition systems. I am feeling pretty dumb so far.
My question here is besides the obvious price difference why would you go with the Dyna 2000 Vs the Dyna S?
Basically I get that the Dyna S replaces the points and uses mostly stock stuff, and the 2000 has a spark control unit like an ECU. Hopefully I'm on track here.
So if I am using my bike just as a street rider nothing special so would I really benefit from one over the other?
There is the third option, stay stock....If you aren't doing anything special, why go through all that expense. If the stock system is working and the sparks sparking, you don't really NEED it....
I am planning on upgrading the ignition regardless. I want it to be more reliable and easier to start so just leaving it isn't in my options.
Why would an electronic ignition be more reliable then points?
Dyna S has a different list of things to think about then points, not really better or worse.
If going with new coils make sure you get the correct Ohm, or understand how to use a lower Ohm coil in the system.
Dyna 2000 is good for a full build that really requires the control and options that it gives. 99% of street engines dont really have a good justification for the added expense.
In my opinion there is zero point to the 2000 on a stock or mild engine. And if a person cant keep a bike with points in tune then they have no business being around a vintage bike in the first place as an electronic ignition is not the only thing "vintage" on a bike.
Join SOHC4 and read up on the Dyna set ups. Also search out the "Hondaman" ignition if you really feel the need to change things.
Mark also sells resistor packs to be used with the lower (3.0 or 2.2) ohm dyna coils.
I understand points and can make them work but the coils and all the electrical is shot out on my bike and I am planning on redoing it all so I just wanted to do an upgrade.
I pretty much thought the same that the 2000 is overkill for what I want to do. I am looking at the Dyna S system with the 5 ohm coils since its totally going to be for street use. I will definitely look into the Hondaman stuff as well. thanks
I don't have a lot of bike history, but I do have a lot of experience with cars. So far what I've encountered in my research is that bike ignitions are still in the dark ages by comparison. At least in the aftermarket world. I have electronic ignition inmy VW racer. Tried and true MSD components with enough power to light a small city.. OK, that is an exaggeration. The point is, it will still fire the plug even if the side electrode is burned off.
My little Suzuki GS300 came with electronic ignition. The control module is not available any where. Should it fail, I'm either stuck, or I'd have to adapt something else. Getting information on that has been virtually impossible.
As such, I'd like to convert mine to points, just for simplicities sake. For example if a control box fails out on the road, you're pretty much stuck. With a point type ignition, I many cases you can make roadside repairs to get yourself home, especially if you carry a spare set of points.
I am new to this forum. Did you ever figure out an ignition for your bike?
There is a new option now in case you didn't.
Why do I see a sales pitch coming? There a probably a dozen electronic systems already on the market.
i have dyna S on quite a few of my bikes
some installs are 20 years old plus and it is a bulletproof system and requires no
work like points will so over that years it has saved me a ton of time and money swapping points
I suspect that C5Paul is from c5ignitions trying to sell product.
They are incredibly expensive and I do not see the value over other available products. In fact I'm not sure I understand their business model.
Wow that's a lot of money for a fairly in needed mod.
If you ride an old bike you shouldn't fear points.
I grew up on points. Cars needed points every year, electronic ignition, much less maintenance.
I converted my CB360 to Pamco's e-advance ignition. . Not afraid of point adjustment, just tired of it. The bike does run better. Starts better. I believe the spark is a little hotter, even when cranking. No floating points either. Points start wearing out the minute the engine rotates and slides on the point's follower.
Having said all that, About $200 is the limit on a good e-ignition. OEM points and condenser cost about $50 a set. 4 sets of points pay for the e-ignition. At the prices for the other e-ignitions, there is no break even place.
