Dynamic balance
rc211v
Due to the new pistons and connecting rods, my mechanic (Ultimate cycle in Hamilton) says I should dynamically balance the crank, rods, pistons and while I'm at it, the clutch basket. He said the only guy he recommends is in the Ajax area. Does anyone know of a place in the Burlington to Oakville area? Better yet Hamilton area. I might make the drive to Ajax anyways since that shop is licenced to work on aircraft engines.
I would assume your fitting a 836cc wiseco kit?another assumption would be carrillo rods.The 836 kit is a drop in application,I doubt the rods are that much heavier,lighter than stock?? there just stronger!! sohc honda's when built to race,are usually shifted at 10- 11,000 rpm,your building a street ride,nothing against your mechanic....but with the mods you have described,your mirrors now might be blurry at 6000 rpm instead of 5000.If you want to spend(lots of) money on the crank....have it lightened,,balanced,and the throws knife edged,,,,,,,weak point in that motor if it's built..is the primary chain,,send some more posts of your build it sounds sweet!!!!! regards JD
Only shop I would trust with that type of work is Concepts on Wheels in Markham. Or maybe Gord Bush.
