electric starter problems
XsjadoTwin
So I CAN run no battery and no electrical start. BUT this is my primary mode of transportation and I wake up early for work and don't have that kick start energy at 530am.
With my current electric start it sounds like its turning but not engaging, or is.slipping. my next day off im going to pull it apart and inspect the gears. How difficult is it to rebuild a starter motor?
Or does anyone have or know of a site that sells NOS starters compatible with the 360?
Or is there anyway of making kick starting it a bit easier? Longer kick lever perhaps? (im a small guy, the jockey type... 115lbs soaking wet) but I can normally get it started by the 3rd kick when I ride it often. But from a day or two cold start it takes a lil sweat. (and I live in AZ where summer morning temps are aleady in the 100's durring worst months) so I don't wanna have to literally break a sweat before heading TO work. Hah.
It's probably your starter clutch slipping and not the actual starter.
To get to it you have to pull the side cover, pull the stator and its attached to the back of the stator.
Inside it has 3 rollers, 3 caps, and 3 springs. Chances are good that your caps are shot.
Parts 5,6 and 23 are what I am talking about, my money is on number 6 (the cap) being worn through.
As far as easier starting, in AZ where its warm a bike should start on half a kick.
Time for a tune up if it takes 3 or more.
Set the timing, set the valves, set point gap, set cam chain tension, etc.
