Electrics on a "brat"
Finnigan
Over 1,000 Posts
Where does everyone that went with this style build hide wires/battery etc. I'm assuming they run a capacitor instead of an actual battery but where is it all hidden?
Most bratstyles I've seen have an obvious battery box in the area between the side covers. As for the rest of the electricals, if you arrange them right, you can fit them in a pretty small area.
I was looking at this pic in particular
It's hard to say but I think I see something near the swing arm. Also, the under side of the seat could be hollow.
If you make your own harness it's gets easy because you are not held by the factory arrangement. You can get a solid state regulator/rectifier that is 3"x3"x1" and be kickstart only, no solenoid then. The particular bike above has no signals so there's no winker.
I think I see what you're talking about near the swing arm, do batteries get that small? I'm planning on having kickstart only so I'll save some space there.
The battery in front is the one I am running in my CB500 which is electric start and still has all accessories. It was $60 from Dime City Cycles and is a 6AH battery. They also have a 4AH battery that is even smaller and cheaper.
http://www.dimecitycycles.com/vintage-cafe-racer-caferacer-bobber-brat-chopper-custom-custom-motorcycle-electronics-parts-small-12v-sealed-trugel-battery-78-0531.html
There are other options as well like Shorai that are potentially smaller and lighter but you'll have to do your own research into Lithium-Ion batteries as it can be a touchy subject.
Some have used very small non-motorcycle 12v batteries (like from alarm systems etc.) and there are very small lithium motorsports batteries available from Shorai, Ballistic etc.
Here's an interesting battery that is about 1/2 the size of a VHS cassette tape:
http://www.amazon.com/PowerStar-AGM-12v-2-3ah-Battery/dp/B000VKM61U/ref=pd_sim_sbs_e_7
2.3A/H might be on the weak side though. Plus it's an SLA which is not my first choice. Many alarm system batteries are SLA.
No, it's just in front of the rear shocks right under the seat. I don't necessarily *Love* how my battery and electronics box turned out so I may redo it later.
