engine cuts out when given some gas grrrrrrrrr
cultclassic
Ok guys , so my bike (78 cb500t) has been sat around not doing a whole lot for the past six months.... i went to start it yesterday and nothing , wouldnt start atall so i charged the battery over night, went back to it a hour ago and after a little work it fired up (just) but when i go to give it a little throttle it cuts out every time :( :(
has anyone else had this problem and could give me a bit of advise on how to sort it out???
many thanks.
Yup. Drain the tank. Clean the carbs. Rip it around the block a few times with some fresh gas. See if that does the trick.
Is this a fairly easy job for someone who hasn't done it before ?
Yeah. There are a couple good walk through type write ups on here. Be thorough, and very organized. Also, as stated by another member... When you think they're clean, do it again as you probobly missed something.
Learning to properly clean and rebuild a carburetor is mandatory when owning an older motorcycle. Should be done at least once a year.
Also... Replace your air filter and clean the airbox and whatnot while your in there. Spend the coin on a good reuseable one like a K&N.
thank you mate, your help is much appreciated. :D
No problem. Its why DTT is here.
A few things to note... If you're going to be storing a bike for awhile its a good idea to drain the carbs completely and add a fuel stabilizer to the tank.
I don't know anything about the history of your bike, so Ill assume the worst. The air filter is probobly 20 years old. Points are likely in need of replacing or at least a clean and reset if you haven't. An oil change probobly wouldnt hurt.
Basically, buy a good shop manual and look for the periodic mantinence section. Do everything in there. Haha. Most importantly, do not assume that the previous owner kept up with any of it. Spend the time and money now to ensure that the bike doesn't fall apart down the road. Maintenance is always cheaper than rebuilding.
Thats exactly my plan, i have ordered a manuel that should be hear anyday :)
I would just like to add that iv just been out to the bike after a few hours and noticed a small rubber pipe ( maybe 30cm long) coming from the bottom of the carbs and doesnt go anywear ,i noticed a fresh patch of what im assuming is petrol on the floor (this come from the pipe) does this need to be attached to anything??? I know the tube from the battery is meant to be like that for any over flow so does the tube from the carb act the same way?
That would be your carb overflow and is designed to keep petrol from entering the cylinder if you leave the petcock open and the floats don't close the valve. It just runs to the ground. Always shut you petcock off when parked to prevent this. So since you have petrol flowing your bog issue could have been a stuck float on the carb overfilling the bowls. good place to start in the diagnosys.
Cheers
