Engine Reassembly Threadlock?
slushie07
I am getting ready to start reassembling my 1976 KZ400 D3 engine that has been completely torn apart. In my manual they reference to different types of threadlock (low and medium). What brand do you guys stick with during engine reassembly. I was thinking of using threebond, or maybe something from the local auto parts store, I even saw that Harbor Freight sells some threadlock although I don't know if I would trust their threadlock in my newly reassembled engine. So what do you guys recommend? As well is there any particular place that I should use anti-seize compound on the threads of fasteners in my engine?
Slushie,
I always use Loctite products on my bikes. They have a product that comes in a stick and is much easier to use than the old liquid in tubes. As for anit-sieze, I use it anywhere you might have to remove the fastners in the future, like the alternator cover, clutch cover, etc. The reason - two dissimialr metals (aluminum and steel) will create a small electrical charge and corrosion starts. I'm convinced that some of the problems we have resurrecting old bikes comes from the PO fooling around and not putting anti-sieze on the bolts!
Scott
Does anti-seize usually come in a tube, or in a bottle with a brush. Also does loctite brand make an anti-seize product? Also I have seen a lot of the different threadlockers say they can withstand heat up to 300 degrees, is this enough for a small motorcycle engine application, or should I use the ones formulated for high heat applications?
Slushie,
What you're looking for at the autoparts store is Loctite 271 - Red (High Strength) and 242 - Blue (Medium Strength). They don't make an anit-seize that I know of. I've been using Permatex in a tube for that. A little goes a long way and you can just rub it into the threads with your finger or a small flux brush. Permatex also makes thread lock products. Permatex and Loctite are both good brands.
One other tip - when you are working with electrical connections on old bikes, pull them apart and clean them with a ScotchBrite pad, steel wool or fine sandpaper and then apply a thin film of di-electric grease before you put them back together. This will help prevent corrosion and give you some moisture protection too.
Scott
Just a little side note. Anti-seize is quite toxic. Although it would take a good bit to really do any damage try not to get too much on your bare skin. It can make you sick.
Alright, all have to make another trip to the auto parts store to pick some of that stuff up. Thanks for all the help and guidance.
