Engine Rebuilt?
Cafe_to_go
Coast to Coast
Just wanted to get your opinion on this, my bike (CB350) is 40yrs old and with less then 2K miles on it, is it worth having the engine rebuilt or just having it tear down to inspect it? The motor runs strong, the only thing I see wrong with it is one of the carb, it works when it wants to.
No reason to rebuild it if it isn't smoking, compression is good etc. etc.
Might want to look at refreshing some seals, and if you want to be thorough do a leak-down test to confirm good compression and valve seals.
Thanks, the bike is not smoking and as to the compression, we did the thumb to the spark plug hole and kick the motor over, the pressure was enough to move your thumb away. I know there is a special tool to check the compression, however I don't have one.
The thumb trick doesn't really tell you much. But an old Honda with only a few K on the clock should not need the rebuild.
Change the oil and insert key - Happy Motoring!
Sound like a freakin dream man. 1+ on the seals and have a tune up done, adjust your cam tensioner, and so on.. and so forth... I'm so freakin jeelous....wish any of my engines were that good.
yeah +1 on not rebuilding it... give it a good tuneup and go. nothing holds oil better than a 40 year old crusty gasket!!!
