I'm trying to fit the Dime City "Shorty" exhaust (http://www.dimecitycycles.com/vintage-cafe-racer-caferacer-bobber-brat-chopper-custom-motorcycle-exhaust-parts-12-inch-shorty-muffler-80-03310.html)onto my CB500, which is fitted with a 4-into-1 system. The problem I'm having is finding accurate specs for the required adapter, so I hope that someone who has tried fitting one of these can help.
The old muffler assembly (which rusted out and was removed) slipped OVER the outlet port of the collection chamber, however since the Dime City SHorty exhaust doesn't look set up to have an adapter fitted to the interior of the slip-on, I'd like to cut a few notches in the 4-1 pipe and slip my adapter on the INSIDE of the 4-1 pipe - that will require an adapter which is 2 1/4" externally to fit inside that pipe.
The other end of that adapter will go on the OUTSIDE of the shorty pipe, and, as far as I can tell, needs to ideally be 1 11/16" INTERNAL to slip over the tail pipe.
So, my questions are:
1. Does anyone make an adapter that measures in finer adjustments than 1/4" or 1/2"? All I can seem to find are ones in those sorts of measurements (for cars, I assume).
2. Is there some different way I can mount the tail pipe assembly I'm not considering, like adapter rings or something? If so, what should I look for that can take me all the way from 2 1/4" all the way down to 1 11/16"?
Thanks as always in advance! --Matt
