No holes, just the dent. I wasn't sure if it would end up restricting #2 exhaust or not. Sounds like I'll just go ahead and clean them up, wrap 'em and bolt them on. Thanks !
cut out the damaged part with a dremel or cut off wheel, then beat the part straight, you may need to heat it a bit to get the shape to come back, and then weld it back in. Grind the welds clean and it will look like it was never damaged.
