When it's running, you should be able to put your hand by the fittings and feel for pressure.
If a valve isn't seating correctly you may get that hissing sound as well.. (someone back me up here)
OK.. third edit.. lol..
I just thought about it, and if you're getting a hissing.. it's probably not through the fitting.. it would have to be from the valve. Just because the pipes are only under pressure when the exhaust valve is open.. (I'm aware that isn't a 100% true statement, as pressure it is always under various forms of pressure).. but enough pressure to buildup and try and escape with a hiss..? It's going to take the path of least resistance.. which means out the exhaust pipe.
I really think you have an exhaust valve not seating properly.. so when you kill the engine, you've left the cylinder on a compression stroke and that exhaust valve is letting the built up pressure seep out.. This could be due to dirty / worn out seats, valves, or springs..
Have you done a valve job?
