extracting a bolt with a mashed up head?
Shooter
The bolt on the front axle that holds in the speedo cable has been well and truly mashed ( not by me I might add).
Looks like it was once a hex or a Phillips (cant tell anymore ...its so rounded out)
No room to cut a slot in it so any suggestions how I can extract the sucker. I do NOT want to munt up the fitting because its part of the hub/axle assembly and I do NOT want to replace that if I screw up (pardon the pun).
Impact driver. The speedo housing is seperate from your wheel/axle. If you removed the wheel, the speedo drive unit would slide right off the axle. If you muck it up they can be bought on eBay etc - you don't need a whole new hub etc.
It is a phillips head (or was). Throw some penetrating oil on it and come back later with an impact driver with the biggest phillips head you have for it and give it a whack.
I had tried that without luck.
I am getting the drill ready and thinking...Bolt/thread extractor !
It is the only stubborn thread I have found on the entire project. Every other bolt and thread has been a dream to shift.
A credit to WD40 /CRC and diligent application by PO's
Have you removed the speedo drive from the wheel? Will make it easier to work on.
The screw extractor works but use the largest one that will fit. The small ones break easily. Also you can heat it with a torch to loosen it.
I got the stubborn little sucker out. Screw Extractor did the trick.
When I reassemble the bike ... every nut,bolt and washer etc will be inspected and replaced if deemed necessary.
