Extracting rear hub studs
edelweiss
Coast to Coast
Please see picture below.
I have seen Roller-type stud extractors to remove the studs, but I don't know if these Roller-type stud extractors will damage the threads of the studs during removal.
Can anyone suggest a safe stud extractor they know won't destroy my studs/threads? Please Note: I have to take the studs out and also put them back in (after powder coating).
Thanks!
John
The ONLY stud extractor I've found that removes studs without any thread damage is the Snap-On CG500
However, it is expensive, over $100.00 when I bought mine, plus the cost of various thread adapters (it only came with inch sizes several years ago)
I know you can get it with metric collets, no idea of price though, one on eBay says 4485 but I think they are smoking something?
http://www.ebay.com/itm/Snap-On-CG500-Stud-Remover-Set-In-Good-Condition-/221459741416?pt=LH_DefaultDomain_0&hash=item3390077ae8
Thanks crazypj. It's amazing how they make these things so difficult. What if I were able to grab the bottom part of the stud that does not have threads on it. That can certainly be turned with a vice grip no? Then again, I really don't want to F up the stud in any way though... The vice grip would gauge the hell out of it.
What about this type of extractor:
https://www.youtube.com/watch?v=fjlnqlWDbfo
Any reason you're intent on removing the studs for powder coating?
And of course if you do remove them and damage them in the process, you can replace with bolts - no need for studs there necessarily. I mean if you're changing sprockets regularly then studs are good to avoid damaging the threads in the hub, but more likely you're going to bolt on a sprocket and change it years later.
Hi Tim,
I need to remove the studs in order to get to the rubber dampers that are in the hub which will melt in the powder coating oven.
Is this Tim from Canada?
edelweiss said:
Hi Tim,
no ! you don't need to remove those studs they have no bearing on removing the rubber dampers
Crap... how do I get to the dampers then? I have a parts manual and saw that diagram, but it looks like the dampers are behind part No.10 (Flange). Are you saying Part No. 10 (Flange) should just come apart from the hub?
Thanks!
yes it should just slide off
there has to be something to physically hold it in postion tho i think that ring-nut #3
post a good pic of your hub
My retaining ring is removed. My buddy just told me... the dampers sometimes get sticky and fuse to the flange. He told me to put the sprocket on temporarily to have something to pull on. Jimmy the flange apart. Wow, glad I posted here. I was all ready to try to get those studs out. Thanks man!
John
There you go! I should have realized the hub came apart - I don't think you even need to remove that retaining ring. It's there to hold the bearing in place (dumb Honda design). The sprocket carrier just pops out of the rubber dampers. Looks like someone spray-bombed it all black without taking it apart, which might make it sticky.
Yup - this is Tim from Canada :)
If it's a 550 the retaining flange is too big to allow sprocket carrier to slide off so has to be removed. I thought you wanted the studs out in case the 400deg affected temper (it shouldn't have any effect - may even strengthen them by stress relieving)
If everything is in good condition the carrier center should be tight on hub. Use a smear of high temp grease when you put it back together. It would also be a good idea to mask off the area where it runs
