factory electronics yay or nay?
vandito.cb
i recently started looking into different battery trays for my cb750. i found 0, but in the process, came across people discussing new batteries, namely lithium ion ones.
the size and weight of them alone seems to be enough to justify paying 3x what i paid for my agm, however, i want to know if the stock electronics, from the lights to the reg/rec, everything can handle these. i'm far from tech savvy as far as battery technology so i'd rather tread lightly than kick myself in the ass when something goes wrong.
i ask this simply because during my time looking into them, i did see, on more than one occasion, someone mentioning the stock charging system can't handle them (not sure why; that's why i'm here).
while on the subject as well, shorai seems to be the ubiquitous brand wherever lithium ion batteries were being discussed (they're now crowding my suggested ads :/). are these the go-to brand for lithium batteries or just the cream of the crop as far being budget friendly?
TIA
LiPo and all the other chemical soup Lithium batteries seem to need two things, a balancing charger to make sure all the cells charge the same and most importantly they need a carefully controlled voltage. Many old bike don't control voltage well and that can lead to battery fires and other fun outcomes.
Some claim to not need the balancing charger and others say to buy a special charger.
Matt "Sonrier" understands those pesky electrons better than I do so hopefully he can shed more light on the subject. What you could do is to run the bike and test the battery voltage that you have right now. Test it at idle, at say 3000 and say 5000 revs to see what the voltage is. If it goes above about 14.5 volts it will fry your LiPo battery.
I suspect that you see SHORAI all the time because that's how adverts work in the digital world. I use Adblocker plus and clear all cookies daily and I rarely see and advert on an XP or WIn 7 or Win 10 machine as long as I use Firefox.
As for all that weight saving, take a dump before you ride and you will save more weight than that battery and it cost nothing. That may not be 100% accurate but I doubt that you would notice the difference on the street.
i'm not interested in the overall weight savings it provides, but more so toting it around all the time (don't ask) and being able to mount it more easily as it won't have the same ~9lb load on any fasteners or brackets i decide to go with.
everything else you said is basically what i'm interested in understanding though. seems some people run them no problem, others strongly advise against doing so unless modernizing and ultimately overhauling the entire electrical system.
sonreir always chimes in on my electrical ?s.
maybe he's napping :/
I like LI-ION. They are lighter and generally have a higher discharge rate (Pulse Cranking Amps) than lead acid. They also self-drain at a MUCH lower rate than lead acid. About 2% per month. My bikes with LI-ION winter over for five months without needing to be on a charger.
Price aside, there are a lot of caveats when using this technology. It is not forgiving.
First up is cell balancing. Not all LI-ION batteries have internal electronics to balance the cells. No special charger can help with this, either the battery can handle it or it won't. Cell balancing isn't critical, but it does ensure the battery lives a long life. Sometimes eight years or more with a well-maintained unit.
Second is charging. LI-ION (and to a lesser extent LiFePO4) requires special charging. At about the 80%-90% mark, ideal charging occurs when the voltage remains the same, but the current diminishes and slowly phases out. Your battery will either have a special charger to help ensure this occurs or it will have internal electronics. Some have neither and this shortens the life of the battery as well.
Next is overcharging. This is the horror stories you hear. Fires, explosions, etc. LI-ION technology suffers from something called thermal runaway. With all circuits, increased heat means increased resistance and increased resistance means more heat and it gets into a bit of a cycle. Also with most circuits, there reaches a point where this cycle diminishes and the heat begins to dissipate faster than it can accumulate. Not so with LI-ION. It continues to increase in temperature until it burns or is shut off. Again, many batteries will have electronics to prevent this (almost all new ones from reputable brands), but not all. The electronics the maker employs may differ as well. Sometimes the electronics help to prevent the voltage from even getting to the battery (this is good) and sometimes the electronics just keep things from exploding (this is also good, but it won't save your battery, it just makes it safer). Anything over 14.5
Then there is over discharging. If the cell voltage drops to less than 2V per cell (around 8V on a 12V battery) the battery begins to dissolve the metal used in the cathode and plate it onto the anode. This damage is irreversible and quickly kills the battery. Not in violent way, though. It's very similar to when a lead acid battery dies. It just stops holding a charge. So basically, you DEFINITELY need to make sure your charging system does not exceed 14.5V. If your charging system does not produce at least 12.5V at idle, you need to be careful about how long you spend idling. It's OK to run off the battery a bit, but keep the revs up if your charging system is weak (Honda twins and singles, this means you).
Finally is cold weather operation. If you're a winter rider, the ability for LI-ION batteries to turn over the starter motor on a cold day is significantly impaired. There is a warm up procedure that involves turning the bike on and letting the coils and headlight draw some power for 60 seconds or so. This heats up the battery enough to get the power you need to turn over the starter motor. This is less prevalent in LiFePO4 batteries than it is with vanilla LI-ION, but it's still a bit of an issue when compared to lead acid.
As you may have noticed, we sell earthX brand batteries from our website. This is the only LI-ION battery we carry because it's the only one I know of that deals with all of the issues I mentioned above. There are internal electronics to help (but not entirely) prevent all of the issues I mentioned above. It's a nice touch that they're engineered and manufactured in the USA, too.
i swear you break things down like reddit's eli5 for but for bikes.
i like it.
i'll check the ones you sell in a sec. everyone seems to think the ultimate goal i have in mind is overall weight savings.
~7lbs to something damn near 700lbs with me on it isn't much, but like i said, toting it around all the time would be much more pleasant less tedious.
do you have any recommendations for voltmeter gauges? i saw one recently that looked to be the size of a cherry but i don't remember where i saw it.
i juuust got finished cleaning up my wiring up front to get rid of any gauges too :/
It may not be a lot of weight savings, but most things on a bike aren't going to be a big weight savings on their own. Its the ounces that add up to the pounds. Every bit helps, I figure (my own weight loss included).
"terminal polarity: universal" as in you have the option to designate either or as + or -?
is that with all li-on batteries or just this earth x one? I'll definitely be purchasing one from you then once I get a few things squared away, financially.
No. Positive will always be positive and negative will always be negative. The universal portion means that the terminals are centered on the battery's midline rather than being offset to either the front or back of the battery. Image attached of a battery with offset terminals. They're located at the front of this battery.
This type of battery usually only fits into the battery box (of a stock bike) in one direction. If you buy the wrong type (offset to the rear, for instance), it's a pain in the ass to hook up.
makes sense...i wasnt sure since the only thing li-on and traditional batteries have in common is that they provide power.
expect a purchase in the near future. i've got my eyes on those indicator lights too.
