First build - 78 cb400
neanyoe
cb400t
Always wanted a bike and I acquired this one through a barter for a camera I no longer use. I'm in healthcare & have no mechanical background but took this on to teach myself the trade & joy of riding something my hands put together, sorta. Since then I've bought a gasket set, oil+filters, plugs, carb rebuild, k&n pods, jets -according to a post on hondatwins & successful doers, you can pod these so I'm going for it
Thanks to Geeto67 (CR forum) I will be:
"its an old bike so hit the basics:"
- swingarm bushings
- neck bearings
- brake pads
-fluids
- fork seals (if they are leaking)
- rear shocks
- carb synch
- tires (if it needs it)
- valve adjustment
- timing chain adjustment
We never had tools or a garage growing up as it was converted to a room so I emptied out our shed and had help making this work bench. Bought tools and now I have this! Should work fine for the winter
My plan is take it completely apart, replace what I need to, rebuild the motor and have it reliable n ready to ride around next spring :)
I rebuilt the carbs and tried starting her up
After posting in the help section, she's alive!
http://youtu.be/R7F6ZJt0GFQ
Re: Niño's first build - 78 cb400
Knowing that she'll run, I went ahead and tore it down even more. I left the electronics there cause honestly they're a bit intimidating! I took a ton of pictures ::) As I was about to pull the motor out.. I realized I forgot to drain the oil first. noob move. Lunch happened and Ill get back to it tomorrow
Welcome to dtt. don't mind o1marc he spent his school years in a class held in a supply closet by his schools boiler room. On the bright side a cheerleader took him to the prom, she was told to, and got extra credit for it.
o1marc said:
Geeto would also tell you naming your bike is ghey.
Dude must have quite a wang if you can stroke it from across the internet
Marc we can't all have real lsr/endurance racer/show/ collectors wet dream bikes. Don't pick on the poor kid.
The funny thing is I can't figure out if you really retarded or just really dumb. I guess it doesn't matter, all roads lead to Rome
