For my mental health I will build a bike - cd200 tracker
Ethanol said:
Beautiful spot. I'm jealous.
Never seen body filler like that. Remember it's a lot easier to do a few thin layers than 1 thick one.
thanks
I think I am going to try a different type next time as I didn't like working with this one. It will be another two weeks or so before I get a chance to sand the filler down and will post some feedback on it
So I finally decided to start working on my project bike again ;)
Started by pulling the tank out of storage with the aim of sanding down the body filler, turns out this body filler is fairly crap of this. some of it started peeling off.
I did a little bit of sanding and soon realized I need to stock up on new sanding pads before I can continue much more. but hey its a start
this is after some sanding
Will have to stock up on a bunch of grits and do most of the finish by hand
Today I went through to my mates whom has kindly let me make use of his blasting box to clean up my engine casings ;D (thanks Mike)
Some of the bits
The box of awesomeness :mwink:
No hang man allowed :biggrin:
First up was the cylinder head
which after a while ended up like this
And then onto the tappet cover
Which also after a good while turned out very nicely
I took a few bits back home to strip the paint off of them and tomorrow I will be heading back early to get a good bit done on the rest of the casings
After they are all sand blasted I am going to go over with with glass bead blasting and eventually onto polishing :)
Ended last night off with some paint stripper which has melted the skin on the tips of my fingers >:(
Can see the bottom right one bubbling away
Today I started at Mike's by removing the old paper gaskets that were being stubborn
And then one at a time stuck bits in and started the slow processes of blasting them clean
The head after blasting
Noticed one of the fins had previously been snapped, added to list of fixes
this runs from the carb to both cylinders
by this point I had already done both side casings and decided to start on the engine block itself
these two pictures where half way to done
bits collecting
Starting to look like an engine slowly
both front and back drum brake things blasted
close up
Then I decided I would clean up a carb and the carb bowl I had spent hours and hours previously polishing
this is a picture of the carb bowl after sand blasting and then bead blasting
And then I got happy and bead blasted one of the drum brake things
And while the bead blasting gives it a great finish, it takes a long time so I decided to cal it a day and come back once I have decided what parts I will polish and what I will paint.
