Fork gators...
Deviant1
Over 1,000 Posts
On my Honda I'm running no front fender. Which is great. But I also have no fork brace and I've noticed it, but not too much. I have a fork brace sitting on another front end right now and I was thinking about painting it and throwing it on. Here's the problem: I really like the look with the gators. Eventually I'm going to repleace the headlight ears and at that point I'll have to figure out something else about the gators. So really I'm looking for opinions and options.... Gators or no gators???
I'm also thinking of maybe running two sets of smaller gators, one above the brace and one below the brace... or just a small set below the brace... Thoughts???
I'm stuck in mid build limbo over this, and believe it or not I spend too much time worrying about this problem...
Thanks,
Alex
You can run a fork brace and gaitors, if that was part of the question? Some people use the inner brace from the stock front fender. Just grind out the rivets holding the fender on, spray it with some black paint and bolt it on like stock.
For the gaitors without fork ears, you can wrap rubber around the fork tubes under the top gaitor clamp area to fill in the gap and keep them clamped in place.
I like the gaitors personally. Have had them on both my 1973 CB500 and my 1975 BMW R75/6. Miss them a bit on my XS650, but I'll live.
got both on my build brother
Okay... so what JRK is running will be what I will end up doing! problem solved... Next topic will be dual disc conversion...
