fork tube fit.
emcarthu
would i be able to use the upper fork tubes off a 78' cb400t on my 72' cl350. i only know that they are both 33mm upper tubes. what else am i missing?
I don't know anything about both models, but if they are both 33mm tubes and are equally spaced apart I can't imagine any problems. Just assuming that there are clamps on top and bottom of the tree?
If they are different lengths it could change the ride height but if you do have clamps top and bottom then just run the tubes into the tree a little higher.
are you talking about the trees or just the tubes? if it is just the tubes all you need to know is what size those are and if they match then yes... if you are talking about the trees you need to know what size the stem is, bearing races, and distance between them
Make it easy..swap in the complete front end,forks, triples,wheel(yuch 19").....cross reference the steering head bearings "service honda .com"
