Forks, shocks, headlights
sc-xc
Unsafe at any speed
Hello to all, I am new to the forum and a friend who works for a motorcycle company is letting me into their overstock. All prices are exactly what I can get them for, I just wanted to pass on a cool deal. Please let me know if you have any questions, I am not able to check this everyday but will get back to you ASAP! Maybe faster if you leave a phone number. I am also open to trades.
I am able to get fork sets with triple clamps for about $150-$175 depending on quantity.
The forks are 29.5 axel to top
5 5/16 wide inside at axle
38mm slider with 48mm stay tube at clamp
28mm stem that is 6" long pressed into lower clamp
they use a 20mm axle.
The forks are Fast Ace ALX07RC if you need further information.
The shocks are right about 10" long with adjustable comp/rebound with a 500lb spring, I don't have a picture but I can get the same shock with a remote res for about the same price. They are shorter than stock but would be good for a solo conversion or if you made a spacer system?
I can get them for about $55 maybe less depending on quantity.
The headlights are 7" diameter with a H-4, high/low bulb and a parking light.
I can get them for about $45 once again less with quantity.
The baja kits have no part numbers on them, they have a cool LED tail, the head light is 35w and them come with the wiring to install, a magnetic pickup speedo and a light control for the bars. You will need to provide a 12v power source.
He wants $200 for the light kits, kinda high if all your going to use is wiring!
Here is one from the back, any particular angle you need?
sc-xc, I'm interested in the forks, shocks and headlight. Can you email me pics? The ones in this post are just so little and I'd like to have a closer look. My email is motobullitt[at]gmail[.]com
The forlks and shock look like chinese pitbike. I race pitbikes and would be very wary of the quality and fitment of them
The forks and shock are fast ace, I think they are a Taiwan company. I have had a set of their forks and shock on my pit bike and have ridden the wheels off the thing with no problems at all..... I'm not sure what other people are using on their chinese pitbikes?
These are not Ohlins but out of the 200 of them that I was looking at they are all the same and seem to be put together pretty good with comp and rebound adjustments in each leg. You can check them out on their website.
I know a couple of Mx companies use them with good success and I believe Zero motorcycles uses them exclusively. I had a set on my RD200 and they worked great but they are a hot rod part! You will need to adapt your steer tube to the forks and make wheel spacers/caliper brackets......
Just figured I would toss it out and see if anyone wanted some while I could get into the stockpile, not something I am trying to turn a buck on.
