frame paint options
bissinger
how did you guys paint your frames?? just spray can and beer. powdercoat or did you have it painted .
Im looking at painting/powerdercoating my frame but 1. dont want to spend a lot of cash as that is at a premium 2. dont want to spend a lot of cash.
If you sprayed your frame with spray can, did it come out nicely and is it holding up. If i go that route, i will be doing the rustoleum flat black, as that seems to be semi durable and is flat,
any insight is appreciated
the best thing you can do for a frame job is the sandblasting. make sure you get this done well and if you go with powder, it'll look great (make sure the coater knows it's a mcy frame so he can pick gasoline resistant powder). you can go with paint too, make sure you use a good etching primer, paint and a shitload of clearcoat (enamel or urethane - not lacquer)
how much does powdercoating usually run?
I get mine done for about $150, the guy does the swingarm, frame, engine mounts, tree clamps, does a really nice job too, there are some places that may charge less, but if you go that route, make sure they know what they're doing
I think my powder job ran about $180... inluded sandblasting the frame, swingwarm, seat sub-frame and headlamp bucket.
Finding one place that does both blasting and coating was tough here in the 204 but it was worth not running the frame between shops racing flash rust.
Best way to go.
i called around and couldnt find too many powdercoat places for a good price. so, im opting for the rattle can ghetto ass job. cant really afford these luxuries since im going back to school and have tuition to deal with.
Por 15
Put a coating of it on first, It's rock hard and you can brush it on. If you do the standard stuff it needs a topcoat or it will turn purple in the sun. Other products of thiers like chassiscoat black are more UV resistant, but I can't tastify to how well they work and topcoating is easy enough. You can get it in an assortment of colors including semigloss black and gloss black. Spray the rattlecan stuff right ontop of it and chips won't show unless they manage to go through the Por15. I coat everything with it.
go to home depot get some EPOXY appliance paint... it is in a rattle can and has appliances on the front of it by rustolum.. by far the tuffest paint out of a rattle can i have EVER used! here is is on my lower forks on a bike did a while back... i do powdercaoting and i use this stuff all the time!
you have to follow the directions though! you have a 1/2 hour window NO MORE!
