from chaft to chain drive.
NINEGEAR
ok this might sound a tad bit stupid. i was wondering how to make a shaft driven bike chain driven. i have never seen a shaft driven bike in person or in a diagram. so i wouldnt know if its posible. i was looking at a bike on craigs list but i dont want a shaft bike so i decided if posible i would change that
Shaft drives are alright. Less maintenance, no mess. Some have an effect called 'shaft jack' (sounds dirty, amirite) that can upset handling because it actually forces the rear tire into the ground on hard acceleration. So instead of squatting, the rear of the bike lifts. Good for straight lines, bad for corners.
When I'm following my friend's cb550sc and he hammers it, you can actually see the rear contact patch double, which explains why it was known as a wheelie bike with only a 130 rear tire.
crazypj said:
What bike?
Sometimes its pretty easy, other times its possible, but will cost couple of thousand dollars and some bikes were just designed that way so it aint possible (eg, BMW, Moto-Guzzi, Honda Goldwing, et.al.)
PJ
a suzuki gs1000. i dont mind the more maintainace for the chain. if the shaft and its parts break it would be harder to get replacements.
I don't know for sure, but Suzuki made 2 GS1000 models, a chain drive and a shaft. I would just keep the shaft, if you change the fluid as needed, it will out last the bike. But the parts may be available to convert the shaft to chain. If the 2 motors are the same. I dont; know that for sure though.
