i have a 73' cb350 twin with front disk brakes that i may like to convert to a drum. it is merely swapping the entire drum wheel and the lower and top triple tree from a 1969-1972 350 bike?
Not quite that simple. Early front ends are narrower than your 73. A 72 front end would be a straight swap but you need the 72 right handlebar control with the brake perch. If you go for this exchange, I would be interested in your disk brake caliper.
a 72 drum wheel, triple tree and the right side handle bar lever/perch... is that right? i hope my steering tapered bearings and spacer can be swapped as well... :/
Don't convert to a substanderd braking system,,,,,,,,,do you value you life????? early drums and linings are junk...retain your g model front brake,,,it's a slight improvement over the drum honda garbage,,and can be improved with better pads(ebc,sbs,classic brake,,,etc etc)........the look might be cool,,,,,hammering on the brakes and squishing it over a cage won't be
i have an entire cb350 drum front end that i'm getting rid of. it's complete except for the headlight, clutch perch, brake/throttle, and the ball bearings!
