front turn signal help please!
stpilotdesmond
Active Member
Gotta 75 CB360 that I just got new (NOT LED) turn signals in for. Problem is, they only have two wires, but the wiring diagram shows three wires for the front turn signals. The strange part is the stock front turn signals only have two wires coming out of them. The extra wires on the wiring diagram on both turn signals is a green wire. The rear turn signals only have two wires in the wiring diagram, so they should be easy to connect.
According to the wiring diagram the right front turn signal has the following wires coming from it:
LB
G
LB/W
Only the LB and LB/W are attached to the turn signal (i'm looking at it in my hand). Where's the green wire and which wire is ground and power?
Same is true for the left front turn signal. The green wire is again, missing. The other wires (O and O/W) do actually exit from the turn signal.
Someone here must have put on new turn signals and should be able to offer me some help. It's much appreciated. Thanks everyone!
