Gas starvation problem
partydog
For what reason would gas not flow from the tank into a single carb..the petcock works..the line is clear..the carbs have been cleaned and all passages blown through with air. I can spray directly into the carb throat and get the bike running but it will not draw fuel through the fule line into the carb.
Have you taken the line off the carb and checked fuel is flowing from the tank? No kinks in the fuel line?
If that checks out, you might have a stuck (closed) float.
The fuel is flowing from the tank...Stuck float eh? would that stop the fuel from even leaving the tank.. guess it 's possible. No fuel will even enter the fuel line when it's all hooked up..
Try cracking the line open a bit just after the petcock. If fuel begins to leak out and into the fuel line then your float isn't opening and not allowing the fuel to flow. If your float is stuck closed then no air can escape through the overflow on the bowls, thus not allowing fuel to flow in it's place.
partydog said:
great advice..I'll be replacing that rock hard fuel line so it won't be a bother to crack it a bit.
Just for clarification, I didn't mean "crack" as in split the fuel line but actually pull it off the petcock barb fitting just enough to let some of the air in the line "escape", while still allowing fuel to flow out of the petcock and into the line. Sorry if it sounds confusing, I'm not the best at describing these things.
