GEARSHIFT SPINDLE CL450
dontaco
Active Member
The gear shift spindle is stripped! The only thing i have left on the engine is this. I hope.
I tried to dremel out new grooves on the spindle and on the shifter i grinded down the opening tso i colud close it tighter around the spindle, but it didnt work that well. So do i have to replace the spindle? Ugh. if so does anyone have a good place for me to start? thanks yo's
don_taco
Ugh! That sounds like no fun at all!
You could get it into 3rd and leave it there. ;D
On a serious note, if you have now already destroyed your shift lever and the spindle, you could try drilling a hole through both of them and putting some kind of pin through it. It couldn't make things any worse.
yea it looks like the person before me tried that but he did a shit job, so now the hole in the spindle is egged (oblong) so if anything its weakened. I usually jam on my shifter so it would eventually get worse. I tried to break the habit of being aggressive on it but im a creature of habit.
So i guess im gonna have to replace it. AARRGGHHHH !!!! If someone has an idea im all ears. Or if i need to take this apart i guess itll force me to get the frame blasted. crud.
Same thing happened to me........got the bike home.................THEN I realized the shifter was welded onto the spindle and was starting to break. This was right before the chain snapped........oh well, life's like that sometimes.....LOL
I ended up getting a "donor" 350 engine that looks like it's gonna end up being in better shape, and since the bike is already completely apart, I'm just gonna try my luck with this engine first.............if it doesn't work, then I'll take the spindle out of it and put it in the other engine.....I just don't want to break into the lower case if I don't have to. I'm sure thats what your thinking too.
Good luck!!
Good luck!!
